Adjustable Tick MC Question
Here they are:
http://www.tickperformance.com/conte...structions.pdf
You really need to read it again, all the info you need is right there.
ADJUSTMENT
Since you increase the amount of fluid the system flows by setting the clutch pedal higher,
adjustment will begin from the shortest setting possible. The pedal will appear to be about halfway down
when compared to its location with the factory cylinder installed. Adjust the turnbuckle in 1-2 turn
increments to lengthen the rod (be sure that the rod coming out of the master cylinder itself isn’t spinning).
After each adjustment, start the car in neutral and attempt to shift into first gear. If it doesn’t go into gear
smoothly, don’t force it (you’ll risk damaging your transmission’s fork pads and/or synchronizers). Simply
continue to lengthen the rod until the transmission will slide into first gear smoothly while stopped. At this
point, test drive the car to fine tune the adjustment to get the necessary release for higher RPM shifting.
DO NOT OVERADJUST THE ROD, or adjust it based on pedal height. If you adjust it to position the
pedal at the factory height, you risk over-extending (thus damaging) the pressure plate.
Once I bled the system and got it adjusted, the pedal sits maybe 1" below the brake pedal.
Almost forgot, AFTER the pedal is adjusted for the correct engagement/disengagement, THEN you can set up the cruise control switch for proper contact, so it doesnt throw codes.
