what fitting for GTO slave cyl.?
I'm trying to put together a stainless steel clutch line for my rx7 swap and I know that the Fbody and GTO slave cyl. have different fittings, but what fitting does the GTO slave use? I know f-body uses the quick disconnect fitting. I need to know so I can order an adapter to work with -3 AN line.
Thanks,
Thanks,
