HELP!!! slave cylinder problems
Old Jun 10, 2012 | 02:51 PM
exodus_gs1's Avatar
Default HELP!!! slave cylinder problems
My buddy has a 04 gto just put a stage 4 t-56 from rpm transmission in and now it seems to loose pressure in the peddle and wont go into gear, is there any upgraded slave cylinders? Or could he use like a zr1 slave cylinder since there in a higher hp car? Idk much about trannies so idk if hp makes a difference. Thanks for any help/advice
Old Jun 10, 2012 | 10:27 PM
LSXFEIN's Avatar
bleed the slave..
Old Jun 10, 2012 | 10:33 PM
exodus_gs1's Avatar
Ok we where thinking it but not 100%. Thanks
Old Jun 10, 2012 | 10:44 PM
LSXFEIN's Avatar
Exclamation should be the issue
you can purchase a Mityvac from most auto parts store. that thing saves you time and stress also butchering your car!
