LS3 Clutch from 2010 Camaro fit in LS1 F body?
Old 06-28-2012 | 06:33 AM
fergymoto's Avatar
Question LS3 Clutch from 2010 Camaro fit in LS1 F body?
Quick question guys. Does anyone know 100% for sure if a complete clutch assembly (flywheel, disc, pressure plate) from a LS3 2010 Camaro will work in a LS1 F body? Thanks!
Old 06-29-2012 | 07:40 AM
zman1969's Avatar
I'd have tyo say no looking at Oreillys auto parts the replacements they offer are different I would think the LS3 would have more holding power but I'm not sure maybe some mfr or distributor would chime in here, seems like would be an easy upgrade
Old 06-29-2012 | 06:19 PM
01_SuperSlow's Avatar
I remember reading somewhere that the LS3 Camaro used the LS7 clutch kit, but not 100% sure. If that's the case then it should fit.
Old 06-30-2012 | 01:52 PM
SNLPerformance's Avatar
They use LS7's from the factory. If you want to put it in it will fit, but, don't expect it to hold much power or abuse.
Old 07-01-2012 | 12:07 AM
fergymoto's Avatar
The car is a stock DD, so that's fine. Thanks for the info.
Quick Reply: LS3 Clutch from 2010 Camaro fit in LS1 F body?
