Trouble with 3rd and sometimes 5th
Whenever I shift into third, shifting up or down, I feel the stick hit something. After I wait a second or less, I can push all the way into gear. If I try to do this quickly, I might grind a little bit even with the clutch pedal all the way in.
I've noticed that if my RPMs are relatively high, 3.5-4K, it's a LOT easier to get it in. If my RPMs are very low, it's also easier but I can still feel that bump as I'm going in.
I can sometimes feel the bump when the engine is off and I move the stick shift around in and out of 3rd.
Sometimes I feel this with fifth, but it's not nearly as bad.
Is the fix as simple as replacing syncros or is my problem even more serious than that even?
