Serious Pilot Bearing Problem
Old Jun 29, 2012 | 08:26 PM
hardasskerry's Avatar
Default Serious Pilot Bearing Problem
has anyone ever seen anything like this before, an if so can someone help me with info on how to remove this pilot bearing please an thank u in advance.
Attached Thumbnails Serious Pilot Bearing Problem-photo-2-1.jpg   Serious Pilot Bearing Problem-photo-1-2.jpg
Old Jun 29, 2012 | 08:33 PM
Rodinator1234's Avatar
I guess you tried a blind hole puller on a slide hammer? That's the only thing I can think of. If there is any way to force the blind hole puller past the ridge in the back of the old bearing and catch a edge of a bearing it should come out. Mine was bad, but not quite that bad and I got it out that way.
Old Jun 29, 2012 | 08:41 PM
I'm going to have to try again in the morning cause it's killing me
Old Jun 30, 2012 | 12:52 AM
jmd's Avatar
jmd
Originally Posted by jmd
i prefer the threaded puller over the slide hammer style. Sk 92522 is a good one.
Old Jun 30, 2012 | 02:00 AM
White6SpdZ28's Avatar
I rented a blind hole puller from autozone.... after beating it and beating it with the supplied slide hammer I got fed up and went to o'reilly. I looked at their pilot bearing removal tool and saw it wouldn't fit, but it did come with a 5lb slide hammer. I used the blind hole puller from autozone, the 5 lb slide hammer from o'reilly, 2 slides and it was out. With the 3 lb slide hammer I must have pounded on the thing for a half hour and it would not budge at all.
Old Jun 30, 2012 | 08:16 AM
If there is one thing in life I hate, that's a under powered hammer. Good job.
