Rebuilding T56. Have a few questions
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
This transmission came out of a C5 Vette. The reason it was removed was because it was grinding when going into all the gears. My first thought was clutch and it seemed fine as far as holding power. However, after the fact, he discovered the pilot bushing was completely shot and that's listed in the manual as could cause gear clash in all gears. My buddy just wanted it pulled apart and everything checked. Got the thing taken apart and have a few questions.
First, the thrust washers are being an absolute bitch to get off. Are these supposed to slide off or have to be pressed off/on? Also, the synchro assemblies all have a groove on one side and the manual does not mention an orientation for these, or if it does, I didn't see it.
The manual also mentions pressing the synchros back on. All the gears have come off without a puller and all the synchros have come right off. Is this a problem?
There's a thrust washer above 2nd gear and it is NOT coming off without a fight. I don't feel good about trying to press it off because the 1-2 synchro assembly is on the other side and I can't get that off until everything else is off. So, any suggestions about getting this off? Should these have to be pressed off?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Haha after re-reading my post, I realized I said the thrust washer above 2nd. It's above 3rd. Not sure why I put 2nd. Anyway, everything's sliding off so I guess I will call someone who knows better than me and see if a new mainshaft will fix it. I'd hate to have to buy new gears and synchros. That would be super expensive. I've noticed the snap rings have been spinning on the mainshaft as well so it looks like whoever rebuilt it to start with didn't use new snap rings...
