Cant disconnect clutch line
The line that goes from the master to the slave cylinder will not disconnect. I tried pushing the white plastic clip and noticed there was a crack in it. I pushed it back and now it wont come forward. Can I fix this or could I just buy a new line?
yeah i had trouble with my greasy *** line.like he said,just keep workin'; it with two screwdrivers.also when u get the white plastic pushed in grab the line and push it towards the slave to relieve the splines.
ok so ive tried using two screw drivers and I can get it so about 1/8 inch of the white plastic is showing but it just wont pop off. I dropped the slave when pullinf it out so only the fitting is on there.
