six speed help
Old 08-02-2012 | 05:45 PM
redtaws6's Avatar
Default six speed help
I ahve a 2000 pontiac trans am. 6 speed
The other day i was at the light and i pushed the clutch in and it stuck. i pushed it again and tried shifting and it wouldnt go into gear. So i pressed on it a bunch of times and if finally came back and is fine. but this morning it did it again. \
Any ideas on what is going on?
Old 08-02-2012 | 06:37 PM
BriGuy's Avatar
Master cylinder maybe.
Old 08-02-2012 | 06:56 PM
Exidous's Avatar
Try bleeding the slave to get some new fluid in there. If that doesn't work you may need to look into a new slave and/or master. Most likely the slave though. They weren't made with the best tolerances.
Old 11-16-2012 | 09:00 PM
thehazz12's Avatar
Probably the slave. COMMON t56 issue. Simple $80 fix. Drop trans. Replace slave. Install trans. Bleed. Drive.
