Wierd T56 noises
Hey i need some fst help on this one guys, I just did a clutch swap and before I designate the clutch let me just say first that it is an unsprung hub triple disc. Wierd thing though is that it runs fine when going up and down through the gears, but when you select a gear you think you should be in after coasting for a period, there is a grinding sound as you accelerate and its worse with more throttle. It goes into the gear just fine , but as you accelerate again there is an aweful noise that sounds almost like the driveshaft it rubbing something, or extremely fast header slap, and I feel it clearly in the shifter. Other wise the thing is awesome and Im really stumped on this one. I hope the trans is fine. It has quite a few miles on it. Any suggestions would be great. Every now and then I feel the grind in first right as I start from a stop but its very short and almost feels like a harmonic or something. The grinding in the other gears will also dissipate as I speed up unless its very sever in which case I change gears and try again. Thanks for any help guys. Questions welcome!
LS1 Cam only full bolt on
Flexplate to crank it
5.5 inch triple disc clutch (button flywheel)
Measured out .109" for TO bearing clearance using a Quartermaster Tri-lite Spec is .100"-.150"
Little tight I know but it fell with in the range. I did it 3 times and came out within 2 or 3 thou every time
Driving it this morning it seems as if it is just a harmonic vibration. ONly lasts from 1000 to 1500 rpm in each gear. Otherwise runs quiet and great. I did notice a little more chatter from the trans as well as idle in neutral, but it seems like that is only due to the lack of rotating mass and a solid hub. Or so I assume
Does it sound like a loud rattle under load until it gets out of those rpms? If so, I am getting this noise too. Only happens when you come out of a corner or take off from a stop and don't go into a low enough gear to stay out of that rpm range. From what I understand it is normal. I wouldn't describe it as a grinding noise, more like a rattle. Sound similar to what you have?
