4th Gear Grind
Old Apr 5, 2004 | 09:03 PM
TexaSS's Avatar
Default 4th Gear Grind
It seems like my gears grind every time i shift into 4th gear, especially when i'm racing.
It normally has no problem with everyday driving, but when i want to have a little fun, it feels like it is having problems going into gear. Have any of you had this problem? suggestions?
Old Apr 6, 2004 | 02:43 PM
Slim's Avatar
I am having the same problem with mine along with some other things that I mentioned in another thread. It is the shop right now and I'll post when I find out what the problem is.
Mine just has a little crunch right before it drops into 4th
Good Luck,
'Chris
Old Apr 8, 2004 | 01:13 PM
FiremansTA's Avatar
Default 4th grind
My 99 TA with 25,000 around miles has the exact same problem! Most of the time it shifts fine, but once in a while I get a quick grind hitting 4th, it's sometimes a little harder under hard accelleration. I have a 3yr warranty on the car (got it last Oct.) so it will be goin' in to the dealer to be looked at.
Old Apr 8, 2004 | 02:51 PM
SStolen's Avatar
synchros are starting to wear.
