Blowout Specials! Upgraded T56 trannys Outright! & Diamond Clutch kits! 3 DAYS ONLY!!
3 T56 Trannys are available OUTRIGHT. No core necessary, but will make you a better deal with a core (condition of your trans will determine price). Outright price $2395 shipped anywhere in the lower 48 states.
These trannys are upgraded with the following parts:
Steel 3/4 shift fork
Billet chromoly 3/4 keys
Billet hardened bronze fork pads 1-4
Billet hardened bronze shifter cup bushing
100% splined 5/6 gears and mainshaft
0.80 fifth gear ratio & 0.63 sixth gear ratio
Optional forward shifter location (3 inches further forward, Cobra shifter location)
Completely rebuilt and upgraded.
Does NOT include bell housing or shifter.
Includes both solenoids and sensors.
Hardware is available: flywheel bolts, pressure plate bolts, slave cyl. bolts, shims, trans to bell housing bolts, and bell housing to block bolts. $60 for all or partial bolt kits available.
ALL Diamond Clutch kits are 10% off !
If you purchase a transmission, take 15% off ANY clutch kit AND get free shipping!For example, the #1 seller, Diamond Stg2 complete kit is normally $759 + shipping, so about $780-800 shipped. Sale price would be $709 shipped, give or take a few bucks.
www.diamondclutch.com
Also, one more T56 is available, but its a little different. Includes all the above upgrades. But this on has Corvette internals (triple cone syncro rings)
Also has the stronger 1-pc countershaft. $2495 shipped.
Gear ratios are exactly the same as the 94-02 f-body; 2.66, 1.78, 1.30, 1.00, 0.74, 0.50
This one can be upgraded to the almighty 32-spline mainshaft for an add'l $500, so $2995 shipped for the Stg3 version.
Call for the specials 8l7-3oo-684o
