which tramsmission?
Old Aug 23, 2012 | 10:44 PM
trevmust's Avatar
Default which tramsmission?
Idk what transmission to put in a weekend warrior type of vehicle. I was thinking a t56, but would a richmond gear work behind a ls3?
Old Aug 24, 2012 | 12:15 AM
trevmust's Avatar
The car is a 1980 el camino btw
Old Aug 24, 2012 | 07:37 AM
garys 68's Avatar
I went with a Richmond 6 speed in my 68 LS2 corvette for 2 reasons.
1) the gear ratios worked better with my newly rebuilt rear end
2) it didn't require tunnel or crossmember mods
You might also consider a TKO
Old Aug 24, 2012 | 08:26 AM
thesource's Avatar
I'm not a real big fan of the Richmond Gear 5 and 6 speeds.
Old Aug 24, 2012 | 02:36 PM
trevmust's Avatar
Is the TKO a hydraulic clutch? thats the main hiccup I see with the tremec t-56
Old Aug 24, 2012 | 03:32 PM
garys 68's Avatar
You can run the TKO with a 621 bell and manual z bar clutch.
Old Aug 24, 2012 | 07:01 PM
trevmust's Avatar
Thanks for the advice
