anybody have experience with exedy clutches?
it looks to me like it is a ls6 clutch i know luk makes some of the best stock replacement clutches on the market and makes serveral manufactures factory clutches as well as most of the performance clutch pressure plates if your car is stock or close to stock id say you will be fine with the clutch just dont expect it to hold alot of power
i was debating on that vs. a spec stage 3 for 300 but it doesnt come with the flywheel. maybe i should just wait on it till i can get an ls7 clutch kit. it seems with spec its hit or miss.
Im currently running that clutch in my car just because I was running a little over budget on the swap. It is a good clutch and it is the same ls6 clutch gm would sell you. However first chance I get I will be going with a stage 2 monster there simply is no comparison lol
