Need help with bleeding clutch
I tried to bleed my clutch today after putting in new transmission, clutch, pressure plate, flywheel, slave cyl and pilot bearing. Now the clutch pedal does not spring back up from the floor, and the fluid in the resivoir does not go down or no bubbles come up through the master cylinder. Can someone please tell me whats wrong with it thanks.
