help!!! lt1 t56 to sbc 400
I've done days of research and have found dozens of stories n write ups but nobody gives details , I have all the lt1 stock parts
I also need to support 575 tq which is y I question the stock bellhousing
I would like to run a hydraulic throwout
Which kind or part numbers do I need for following
Bellhousing
Flywheel
Throwout
I know some have used all stock lt1 parts but I'm sure I can't
Oh and most important at lowest cost possible please
It is internally bal.
Bellhousing
Flywheel
Throwout
Thank you , yeah I've heard That but then I still have to put a high tq clutch n p.p
Guess I forgot to add n op that will the lt1 bellhousing hold that kind of power too
I mean I could also just call kiesler or mcloud and other but I'm trying to do this at lowest cost possible n still hold up I don't feel like spending 1000 just bolting up tranny
Appreciate the help , plus a lot of places say bolts up to t56 but they don't specify
Ls1/lt1
Went to summit today n QuickTime have a kit but they couldn't tell me lt1/ls1
Ls1/lt1
The bell housing doesn't hold horse power. Its merely a housing connecting the engine to the transmission and providing a cover for the clutch and flywheel. Now if something in the clutch or flywheel lets go, the factory housing does a poor job of containing it. This is where a scatter shield like Quicktime makes comes in to play.
Huh I was thinking to twist from the crank would tweak it ,
Could u tell me if it would be a smart route to stay with the factory pull style setup or to go hydraulic throw out
Cuz if I do go the custom flywheel route I will have to stay with it correct?
What are the pros cons of converting to push (worth it)? I'm just trying to get this thing running before Dec n still need heads n valvetrain which is y I'm trying to save cash but at the same time wanna do it right
400, bell, centerforce, cluch, compatible, connecting, flywheel, lt1, older, put, sbc, sbc400, t56, transmission, transmissions
