Beefing up the T56
What parts with in the trans should I look at replacing/strenghting and does anyone sell a upgrade kit?
(1) Hardened bronze shift fork pads for the 1-2 shift fork and 3-4 shift fork. This is not conventional bronze as its 5x harder. Replaces the stock plastic pads.
(2) Bronze shifter cup bushing. Same material as the 1-4 pads, listed above.
(3) Billet keys for 1-2 and 3-4. These keys are CNC-machined from chromoly alloy, which is virtually impossible to break. Replaces the stock stamped steel keys that tend to break.
(4) Steel 3-4 shift fork. Replaces the stock aluminum fork. This will give you much more rigidity.
(5) Re-machine the mainshaft 5/6 journals. This is a "fix" for the notorious problem with the 5/6 cluster gear working loose on the mainshaft. Its a poor design from the factory that allows the gear to wobble and can cause high speed vibration issues. Can also destroy the splines on the mainshaft and strip out the 5/6 gear completely, in the worst case. This "fix" will eliminate this problem all together.
$425 for everything listed above. Mainshafts are done on an exchange basis. Of course, if you send the trans in to us for the build, the Stg1 basic build is $275 labor & $300 parts. Add this to the upgrades and theres your price. Add'l gears or other non-wear items will cost more, if needed.
3-4 steel fork is a good idea...I had one installed last year, no difference in feel but at least i know it won't bend.
I want to try carbon rings as it sounds like it would be a worth while mod. would also improve shifting charactersitics
i'm in Canada too and it bothers me that i would have to ship my tranny for upgrades...not many shops specialize in the T56 up here and if they can do the work, they will ask for your limbs. I hope you have good insurance
