WOT 1-2 shift problem
Old Sep 29, 2012 | 03:33 PM
Violatorno1's Avatar
Default WOT 1-2 shift problem
I have search this forum the best I could but have yet to find basically a solid answer.
Normal driving and the trans seems to shift flawlessly through all the gears but at WOT and trying to hit 2nd at high RPM's is a task in itself. If I depress the clutch and pull it down somewhat slowly it'll take 2nd fine but trying to depress/shift 2nd quick she'll be tough to pull and usually will make a quick grind or it just doesn't go and a second attempt is needed.
This has happened with both a SPEC 3 and a Centerforce 12in clutch. Is it time I pull this trans and go inside? I've heard of the 3-4 fork problems but unsure of the possibilities of this 1-2 high rpm problem.
Anyone with words of wisdom?
