Weight of clutch discs
Old Oct 1, 2012 | 08:49 AM
Rob94hawk's Avatar
Default Weight of clutch discs
Didn't think about this until after it was installed but on the left is the Spec stage 2 Kevlar and on the right is the Spec stage 1 (don't know the material.) Thought the Kevlar felt lighter but didn't think anything of it until I started driving it. My Seat-of-my-pantsometer tells me there is a quicker response in the revs. I'm only in the break in period at the moment and I'm taking it easy but I was wondering if it was just me or would the lighter disc, even if it's just ~3 pounds have an impact on revs. Thanx
Old Oct 1, 2012 | 10:01 AM
SPEC-01's Avatar
Faster gains and losses in RPM are related to the total rotational mass of the assembly (including the flywheel, plate and disc). You may see a minor improvement with a lighter disc but most weight reduction occurs relative to use of a lighter flywheel or even an aluminum pressure-plate option. It is much more likely that you are noticing a difference associated with a clutch that is actually holding versus one that is worn out and slipping (even if slippage is minor).
