Spec Stage 3 Clutch is slipping!
I drove my car today which was the first time I drove it all week and the clutch started slipping at first it really wasn't bad. I only drove it for a few miles on the way back home it got really bad. What do I do I bought the clutch kit from eastside performance about a month ago. Will Spec warranty the clutch? It maybe has a 1000 miles on it now and I broke it in for over 500 miles.
1 Post
Maybe something went wrong with the install, but I'm sure that either East Side or Spec will help you out with your problem. Just give them a call.
I installed it i did it just like the instructions said I used install university to help with some of my question the transmission was also rebuilt and I put a new slave cylinder on it too. The clutch chattered pretty bad coming out of first I thought that it would go away like most people said it would. I also heard a few times when I would pop it out of first and sometimes second a little squealling noise could it have been the throw-out bearing? Could the TO bearing cause it to slip or could the slave cylinder be bad? I am going to pull the tranny out this weekend and take a look. Is there anything I sould look for?
Be sure you are not leaking some sort of fluid onto the clutch... Thats about the only thing I can think of that would cause a clutch to just go away gradually with out some sort of abuse.
