T56 Grinding in 4th only when releasing clutch??
Hi everyone, I just rebuilt my T56, but when selecting 4th gear, it goes into gear, but grinds when only when releasing the clutch and pushes the shifter out of 4th. But when I pull and hold the shifter in 4th gear, there's no grinds and it's able to drive smoothly.
Here is a picture of the 4th gear BEFORE the rebuild, please keep in mind i changed out the worn out syncro right under the slider. I know the 4th gear shows some wear, but do you think it's the culprit to my problem? Any suggestions would help a lot. Thanks for your time.
What was the input end play at build-up? excessive end play could cause this. Was the 3/4 forl rail hole ( key shaped hole) wallowed out?.......allowing excessive fork rock. If it has an iron fork this wallow/ wear in unlikely. Were the fork pads worn? If the pads were bronze, did you glue them on? Fallen off pads could cause this.
