Slave Bolt question
Old Oct 22, 2012 | 01:49 PM
69LT4's Avatar
Default Slave Bolt question
Making the switch to an LS2 and T56. Can I use hex head bolts to install the slave to the trans? Wasn't sure if there are clearance issues. Also, do I need to put treadlocker on them? I believe 90 in-lb torque.
Thanks,
Kevin
Old Oct 22, 2012 | 02:09 PM
redbird555's Avatar
My t56 didnt come with the slave bolts so I just went to lowes and got the correct size and used a little bit of blue loctite. so far no issues
Old Oct 22, 2012 | 03:19 PM
Bacon's Avatar
I just took mine out last night and the bolts were hex cap bolts with a 10mm socket head. Blue loctite and 88in-lbs
Old Oct 22, 2012 | 08:26 PM
69LT4's Avatar
Great. Thanks guys. Didn't want to have issues later once it's in.
Kevin
