grinds in 4th
Old Dec 10, 2012 | 09:58 PM
chevybayboy's Avatar
Default grinds in 4th
Ok I Did a t56 swap with the spec stage 2 and the gears grind going into 4th only when the rpms are above 1500?? Are my sync rows going out or is my clutch not engaging all the way also it seems my steering wheel hasn't been the same since swap like my horn doesn't work anymore and I keep blowing fuses for my turn signal any advice?
Old Dec 11, 2012 | 07:05 PM
Anyone?
Old Dec 12, 2012 | 08:49 AM
calhoon's Avatar
where did you get the trans? 3rd/4th issues can happen with the OE aluminum fork. Also you synchronizers could be worn. As for the wiring...check your work. Manual Transmissions usually don't blow fuses.
Old Dec 12, 2012 | 09:17 AM
A buddy of mine he said that the tranny shifted fine like butter but now I'm thinking he needs to refund me some money to get this issue fixed
