t56 countershaft bearings (which is which?!?!)
Im assembling my T56 and I'm at the point where I have the housing on and now i have to finish assembling the countershaft extension but I've run into a problem. I have three bearings two of which go on the extension countershaft and one on the main shaft. The two that go on the ES are "110 Bearing, 6th Gear Needle" and "127, Bearing 5th Gear Needle" I know 127 goes on the bottom, but I'm not sure between 110 and "72,Bearing reverse gear"(goes on input shaft) So my question is which goes where? I need to know before i press on the 5/6 driven.
I tried uploading pictures of the gears but they wouldn't upload so if you need them for more clarification just ask and I'll email them to you or something along the lines of that.
