Slave plate?
I will post pics soon.
http://www.speedinc.com/cont.cfm?cid=C0000737
If so keep it on. If moves the slave closer to the clutch. Helps disengage more.
My car did not have one I installed one that came with my new clutch. worked fine then I removed it when i changed my new clutch after the old one went bad. At high RPM when I would 2-step the car would roll off the line and burn my clutch. I put it back in and fixed it.
So I say keep it.
So I say keep it.
