Strange high speed vibe ONLY when clutching.
Okay here we go with weird high speed vibes again.
This only really happens above 70MPH or so and ONLY when clutching to change gears or just coasting (clutch pressed) with no load applied. When the clutch is engaged (not pushed) regardless of speed or gear, its smooth as silk and perfectly fine.
When this vibe happens, I feel it in the shifter and in the floorboard so I leaning towards it being tranny or clutch related and I am not really sure when it started.
Thoughts???
Thoughts???
