this is weird
Old Jan 27, 2013 | 09:45 PM
clean98z-28's Avatar
Default this is weird
Last night my buddy grenaded his rear end on his 96z28. and for some reason now it wont go into any gear except 5 6 and reverse. got under the car and the drive shaft wont move most likely cuz of the rear end. we both spin the rear tires in the same direction and it spins freely. there is little movement in neutral like the shifter wont move over to where 1 2 3 4 is. makes no sense to me
Old Jan 28, 2013 | 10:52 AM
Anyone?
Old Jan 29, 2013 | 07:12 PM
help please
Old Jan 29, 2013 | 07:53 PM
S10xGN's Avatar
Was there a question? Pull the driveshaft and check it again. If the rear-end locked up under load, it may have damaged the trans, but you'll not be able to do a diagnosis until the 'shaft is removed.
Old Jan 30, 2013 | 03:27 PM
388_stroker's Avatar
Shift linkage sounds dicked up if you cant get it into 1-4... my 5/6 fork broke and I couldn't get it into those gears at all. Better start taking stuff apart and diagnosing! Best of luck
