t56 stage 2 from tdp vs. t56 magnum from summit?
I'm looking into buying or rebuilding my t56 n don't know what to do if to get the stage 2 from texasdrivetrainperformance or the t56 magnum from summit?only thing wrong with mine is no 5,6 n all gears grind
T56 stage2 $1000-$1800
T56 magnum $3000 but will withstand up to 700 ft.-lbs of torque
Thanks everyone! It takes moderate modifications to adapt an f-body tailhousing to the Magnum. That's why the built/upgraded Magnum w/ SSR tailhousing sells for $4200-5000 depending on where you buy it. So you chose wisely ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Jason
Jason
