Help with diagnosing my Terminator X
Second problem popped up after trying to figure out if the second fuel pump was working. I have a Racetronix twin 340 in-tank setup. It comes with a double pump hotwire harness that I have wired directly to the alternator. See here: https://www.racetronix.biz/p/udp-hd-...mp280/udph-005. Both pumps have ground switched relays out back. In a factory configuration using the factory PCM, each pump has a connector with a jumper wire so they both switch on at the same time. I didn't want that, so I used the Holley's green fuel pump wire and tied that into my integration harness's fuel pump request wire. This sends the request through the factory relay/fuse setup first, and then back to the relay in the rear of the car. On this pump, I left the jumper wire in place, as it allows the factory computer to control the pump as normal. Prior to testing to see if the second pump would turn on, the first pump worked fine. The second pump uses a ground side switched output from the Terminator X that's supposed to turn on at 2 psi boost and above 3000 RPM. We did some testing and found 61 Ohms resistance to ground when the pump was commanded on, which didn't sound right. Either way, my main problem occurred when I disconnected the output from the Holley and instead replaced it with the jumper that comes in the Racetronix kit. I meant to disconnect it after testing, but I drove the car for a few minutes with it. I figured that out, and reconnected everything as it was. However, every time the car goes into boost now, the fuel pump shuts right off. Like the green fuel pump output wire is shutting off the pump, nothing else makes sense. As soon as it's out of boost, fuel pressure goes back to normal. Every time it hits boost, instantly shuts off. Anyone have any idea what I should look for?
I posted this up on the Holley forum as well, and it was suggested to do a firmware update, so I'll make a go of that - In the meantime I just wanted to see if anyone has ran across either of these issues or knows what could cause them.
That said I attempted to use the same harness on my car going thru the factory relay and it flat out didn't work. For whatever reason I couldn't get power to the pumps using that harness. I was diagnosing it for like 3 days along side of talking to Racetronix and after all of that they still said it was something I was overlooking. I pulled it out cut up the harness and wired the pumps up and haven't had an issue since. Good luck.
Edit: Yes it does have that function. No need to pull any relays just hook up your laptop, key on and hit the output test button at the top. It'll show all your outputs and you can turn each one on from there
I did some diagnostics on the secondary fuel pump not turning on, and I don't know what is causing it yet. I verified that both pumps function correctly by switching which pump is the primary and which is secondary. I did an output test for the secondary pump, which is on pin B10, and it didn't turn on. I hooked my volt meter to the output and set it to ohms, and when I triggered the output, it was reading 40-60 ohms. I'm wondering if I have the secondary pump wired incorrectly? Here is a pic of where it gets tied into the double pump harness: https://www.racetronix.com/product/F...PH-005-1-L.jpg I left one of those looped terminals in, so the factory relay turns on the pump. That part works fine, and is triggered by the green fuel pump output wire on the Holley.
If you look at the pic, there's a black ground wire on one side of the terminal, and a red (or blue) wire on the other side of the terminal. The black ground wire is grounded to a stud on the engine adjacent to the alternator. The red wire goes to a relay for pump 1, the blue goes to a relay for pump 2. I used the output on B10 ( Grey w/ black stripe ) and made a terminal so it plugs into the double pump harness and connects to the blue wire. The opposite cavity I left empty, as I assumed it was no longer needed. My sensor ground from my Terminator X is grounded to my unibody under my passenger side kick panel. I ground the paint to bare metal before screwing it in, so I know it's making a good ground. In the rear of the car where the dual pump harness relays are located, there's another ground which I also attached to the unibody. There is also this intermediate harness that plugs into my stock '98 wiring: https://cdn.racetronix.biz/mmrtx/ima...pg?w=800&h=800 It has a ground that bolts to a stud I installed on top of the sender. 3 wires come out of the harness and go into the factory bulkhead under the car. Grey is fuel pump command, purple and black are for the gas gauge ( which doesn't work, but that's another problem ). The output is functioning correctly from what I can see, but is the 40-60 ohm reading plausible? When I have the connector plugged in and command the output on, there's no reaction from the pump. I'm at a loss here, wiring is not my specialty.
I will have to double check later but I am pretty sure with the Terminator we couldnt run the second pump off of a ground trigger as well and had to go with a 12v signal to activate the second pump.
Mine is set up to turn on at 3/4 throttle and works great.
If still need help I will look this afternoon.
