Will this D&D knob fit my shifter?
no it wont but i made one work with my car. if you buy the **** you can drill out the plastic inside. convert 16mm to standard and thats the bit you will need after that you can either get an m16x1.25 tap and tap it for a stndard shifter or do what did and put the shift rod in a vice and force thread the **** on. its made of plastic so the shifter will cut the threads. mine hold like a rock no problems.
