New Transmission w/ Same Problems! HELP!
About 10,000mi ago (only 72,000 on the car) my old T56 started to get really hard to get into reverse. After a week of that problem I replaced the clutch master cylinder w/ a brand new AC Delco unit and performed the drill mod on the clutch line. The problem stayed exactly the same, but two weeks later my car started popping out of reverse. I toughed it out for a year until last weekend when I replaced the transmission with a used one bought off a friend of a friend. I also dropped in a monster level 2 and new slave cylinder. Now this transmission seems worse than my old one, but has the same problems. It is hard to get into most gears just like the old one, but this one grinds third and sometimes fourth. At least it doesn't jump out of reverse... as often. The new clutch and slave cylinder seem solid. The pedal only has about a 1/2" off play at the top of the swing and the clutch engages about 1/4 of the way from the floor board.
What the hell is going on?!?! Is there something I'm missing?
He's also my dad's boss so I have to be sure that it's messed up before I start throwing around accusations
Also, something to watch for with T56 clutches is some require shimming of the slave cylinder to get proper engagement/ disengagement. Not sure if this is the case with Monster clutches or not, but I would ask them directly.
Was your flywheel machined or replaced at the same time as the clutch replacement? I have had some machine shops add a step or machine to much of a step on flywheels causing a dragging clucth as well.
Monster clutches do not need shims. It says so in their instructions. The pedal has the perfect amount of play before engagement right now.
I'm pretty sure that all monster clutches come with a matching flywheel (I'm assuming they don't match up to stock flywheels?). I installed the new one with my clutch and cleaned and prepped it per monster's instructions.
Thanks for the help though!
I guess its time to learn how to rebuild a T-56!
