Clutch recommendation
Having swapped over to a t56 from the 4l60e, and reusing a used 11" Dual Friction Centerforce clutch that was in there from the wrecked car I bought, I've found that the 370 some odd ft/lbs of torque I'm throwing down is making the clutch slip during shifts (unknown mileage on the clutch itself). It also had the Centerforce Billet Steel flywheel as well that I could reuse.
so I was wondering if anyone could recommend a good clutch (probably a single disc, for price) that could handle and be reasonably street-able with a twin turbo setup that would put down 7-800hp reliably?
I was looking at a 12" Dual friction, as supposedly they're supposed to be up there in torque ratings, but a few associates have recommended giving Ram clutches a call. So I figured I'd ask the tech and see what you guys think, more opinions the better right?
If you want a clutch that will handle your current power level and other FI mods down the road, go with a Monster stage 5/6. I personally had a stage 3 but changed to the stage 5 which required 0 break in miles and had 0 chatter. The 5 handled DD duties with ease and was quiet, and when I added a supercharger and was making 750rw it never slipped once.
Now Im going with a 402ci with a D1SC and a possible shot of nitrous. Aiming for 850-1000rw so I'm about to go with one of Monsters new Twin Disk units.
http://www.specclutch.com/cars/Chevy/Camaro/1998/Single
