What does this problem sound like?
Car has a cartek clutch, 01+ hydraulics with a Cartek adjustable master, FYI. Stock tranny (and original fluid).
The shift effort is never any more difficult than any other gear, there's no other strange sounds, blah blah blah.
Does this sound like synchros? Bent shift fork? Maybe fluid related? I'm going to swap out the fluid with some GM Synchromesh in a weekend or two, and see if that makes any difference. Barring that, is it definitely time for a rebuild? I am replacing the clutch in a few weeks and it would be much easier to swap the tranny at that point, instead of taking the entire car apart again (swapping clutch or tranny in a C5 involves dropping the entire rear subframe and associated parts, I'd rather do it once!). On the other hand, if it's not the tranny, I'd hate to waste the $$$!
Dope
Car is running great. It hasn't been to the track yet, hell it just started getting warm a week ago. It's getting all new brakes in a week or two. I'd love to do more work on it but between the clutch and now possible tranny problems on the vette, the wallet is hurting!
Btw, did you know the car has 3.73s in it? I don't think you ever mentioned it, but I noticed it a few weeks after I bought it.
Dope
I do have a BPP shifter, and it does not have stops (they don't come with them). I wonder if the car was previously overshifted into 4th enough times to dent the casing, and cause problems.
Dope
When you put it in gear is it kinda like slicing through butter. Hard on the top then it goes into gear. That what the camaro felt like. It will only get worse. The camaro got me caught in traffic because of it sticking in 4th. ....kinda hard to take off fast in 4th gear....Hows the camaro tranny working?
I didnt get a new car yet. Im buying a house in the next month or two so I need the money for that. The only car I have is an 03 cavalier base model, auto 4 banger. I planned on getting another camaro so I got the cheapest new car I could get. I only paid like $9000 for it. My next camaro is going to be a stripper so I can do a heads/cam package with the money saved. Good luck with the Vette.
