My clutch on my 2000 trans am
Has the flywheel been machined and reused previously? If not, then it should be fine to cut it and reuse it. Check the total thickness of the flywheel and let me know what you see. I will be happy to let you know if it is within a usable thickness range. Also, let me know what you planned torque output is and I will be happy to make a clutch recommendation too.
