Sachs1050 flywheel and high HP clutch combo
I have a sachs 1050 flywheel for my turbo'd LQ4 in my 71' C10 truck. Im using this because of its thickness to work with my Muncie. Im looking for a clutch to match this flywheel that will handle about 800+Hp. Im running an auto gear M22 tranny with 1-1/8" 26 spline input shaft manual clutch linkage.
Just for fun I tried my lining up my old SBC clutch to this flywheel, it looks like the bolt pattern is the same, but the pressure plate did not line up correctly.
What are my high horsepower clutch options for this flywheel? I prefer a twin disk for a lighter pedal. I plan to run slicks at the track.
![](http://i1278.photobucket.com/albums/y518/benlugchev/c10%20build/IMG_3226_zps7d0ff3fa.jpg)
