Drill mod question
Old Mar 25, 2013 | 12:56 PM
Bowtie-Bri's Avatar
Default Drill mod question
I have the stainless line in hand. I know that everyone says when doing the "drill mod" use a 1/8" drill bit. Has anyone used a 9/64" bit instead?
Is it imperative to use the 1/8th bit?
I know it sounds like a dumb question,
but I don't have one in my box and the 9/64 bit is the next size up from the 1/8th bit.
Flog me with a wet noodle if you think it's a dumb question, but I had to ask.
Thanks,
Brian
Old Mar 25, 2013 | 01:13 PM
slow ride 02's Avatar
Thanks,
Brian
I havent done the drill mod yet. I would like to think that .019 would not make any difference. I guess that it really depends on the I.D. of the hose.
Old Mar 28, 2013 | 07:34 AM
Camaro9969's Avatar
I have done the drill mod. You could use the biggest bit without ruining the line just go slow and do not get any shavings in there. But take it from me and my experience its only a temp solution i had so many issues i did everything from new clutch slave master drill mod and still had pressure issues till i did a Tick master.
Old Mar 28, 2013 | 08:52 AM
oange ss's Avatar
i used the 9/64 bit, but save yourself the trouble and buy the aftermarket hose
Old Mar 28, 2013 | 10:05 AM
FST SS's Avatar
This, get a Tick. Same experience I had.
Old Mar 28, 2013 | 10:34 AM
Bowtie-Bri's Avatar
Thanks Guys for the good info. I used the 9/64 bit. I replaced the clutch master cyl. and have it installed. Now I just need to bleed it and hope for the best.
Old Mar 29, 2013 | 09:00 AM
Camaro9969's Avatar
Good luck man. I have been there trust me. Clutch sticking to the floor down the track, one time i actually tied the clutch pedal to my foot lol
I tried bleeding it took so long i gave up and went and bought a mity vac it took not every 20 seconds and it was perfect.
