Which Slave Cylinder????
Old Apr 15, 2013 | 08:27 PM
3rdCoastPowerSports's Avatar
Default Which Slave Cylinder????
The one on the left is from autozone and is cast AP. The one on the right if from orilley and is also cast AP. They are the same parts number. However they are not the same, they look the same but the casing methods are different. Does anyone know which one is the good AP casting? If my memory serves me correctly it the one on the left with the fatter lettering. Please don't post or comment if you do not have personal first person experience, thank you.
Uploaded with ImageShack.us
Old Apr 15, 2013 | 08:32 PM
they both are stamped with the same part number and the same ap but the one from autozone (left) is marked 2 while the cylinder from orilley (right) is marked 3. also they are both slave cylinders for a 2002 camaro ss
Old Apr 16, 2013 | 10:57 AM
SNLPerformance's Avatar
The unit on the right is a newer one, the single digit number that you see is a "date code".
And yes, I'd say I've got a little experience in this.
Old Apr 16, 2013 | 11:14 AM
Thank you! Is one date code superior over the other date code?
Old Apr 16, 2013 | 02:06 PM
Either will work fine. Take your pic or use the one that was cheaper and go get your money back if you have purchased both already.
Old May 14, 2013 | 05:29 PM
94LS1B4C's Avatar
I've heard that AP cast all gm LS slave cylinders making the new gm part number 24264182 The same as the one pictured above... is this true?
Old May 15, 2013 | 07:38 AM
usdmholden's Avatar
What is the advantage of old casting vs new casting?
Old May 15, 2013 | 02:38 PM
All the AP cast slaves i have had in my hands have had the part number D951004 stamped on them. Advantages of the old to new castings? I would guess none. I used both the slaves in the pics and they both worked out great. Both customers were very happy
