clutch pedal problem
Old Apr 23, 2004 | 12:55 AM
armkneez8's Avatar
Default clutch pedal problem
Just put a Dual Friction clutch from Centerforce.You can't feel pedal pressure. Also the pedal doesn't engage until you step down all the way to the floor.can't shift right or go on reverse. Anybody know what's going on???
Old Apr 23, 2004 | 03:16 AM
SSactionLs1's Avatar
did you bleed the clutch hydros?
Old Apr 25, 2004 | 09:10 PM
armkneez8's Avatar
Yea but what else can be the problem, I have to turn my car off to shift to the next gear this is f@#$ed up. Anybody know what's up?Thanx
Old Apr 25, 2004 | 10:18 PM
99MONGOOSE's Avatar
Get an adjustable master cylinder and make sure you have a good up to date slave cylinder. You will have to make sure you have ALL the air out of the system.
Old Apr 27, 2004 | 12:52 AM
armkneez8's Avatar
How much is it to replace the whole hydraulic system of the clutch? (McLeod or what).And what exactly does the drill mod do to the hydraualic system?Thanx
Old Apr 27, 2004 | 03:13 AM
SCFirst24611's Avatar
Sounds like it just needs to be bled. I did the drill mod then I thought I bled the system then I lost all pressure. Just might wan to check the bleeding process again
Old Apr 27, 2004 | 01:34 PM
armkneez8's Avatar
Was that on a stock hydraulic system or an aftermarket? can i do it on a stock or should i just buy a McLeod? What's better for the buck? Thankx
