Newbie Questions.
Old Apr 23, 2004 | 03:26 PM
Taco's Avatar
Default Newbie Questions.
I'm going from a stock cube, S2 H&C (B1 Cam) setup to a 383 Stroker with same heads and bigger cam. I am also going from a 3.73 geared stock rear end to a 9". I may run ET Streets some, and I need advice on a clutch that will hold the torque and tires, and I need to know about reliability of a stock T-56 on some pretty gnarly launches.
The car is my daily driver, so I need to know if I can wring it's neck or if I need to take it easy on it.
Thanks in advance for the great advice I know to expect from LS1Tech guru's!
Taco
Old Apr 23, 2004 | 04:23 PM
Fireball's Avatar
I run the RAM 910 clutch. It has taken everything I've thrown at it (its recently seen alot of 1.5x 60-s and has been as low as 1.47). The only problems I've had are tearing up 2nd gear and locking the tranny in 4th. The latter was caused by a driveshaft that was too long I think.
I haven't had in tranny issues due to any hard launches per say.
