Tick Master
Old May 10, 2013 | 01:57 PM
Mista Blazer's Avatar
Default Tick Master
Ok, so im in the process of my t56 swap, i have a Tick that i will be using for the MC. i dont have the slightest clue as to where, what, or how to get a u-bolt. Can i install the Tick without the ubolt? i hear some people do this.
Old May 10, 2013 | 04:05 PM
redbird555's Avatar
The tick doesnt use a u bolt. It comes with 2 bolts to thread into the mounting block. But remember since the auto has that stud in the firewall for the cable the tick wont fit. You need to cut off the stud from the outside of the firewall. I used an air chisel and also remember to add the bracing plate in the spot for the m/c
