Cheapest 1000 hp 6speed Trans
Looking to up grade or replace my trans for as cheap as possible to withstand 1000hp(im a diehard manual guy). Is it better to get another type of transmission or what are my options? Im sorry if this topic has already been brough up but ive researched alot and havent found anything.
www.rpmtransmissions.com
cheap and 1000hp dont go together though. do you actually make that kind of power?
Haha I really wanna stick to stick. Something around $2-3k would be awesome. Just everything that Ive seen is $5k and thats pushing it for me. Im not at 1,000 yet but Im doing all the supporting mods before slappin a turbo or procharger on there. I could probly put the parts together if I got a kit too?
Tick performance here. I have their level 5 SuperMagnum TR6060. I am making a 1000 rwhp. I chose Tick because for the same money as another sponsor here you get more. Like the cryo treating or polishing (one or the other) is part of the level 5 Tick but costs extra on others.
And for the record there is no comparison between how these TR6060's shift and the stock T56. The T56 is a granny gear 4 speed next a built TR6060.
If you can afford $3K go with a T56 Magnum (TR6060 based) and never look back.
As stated the shifting smoothness is no comparison. Already has a 31 spline output shaft, all gears/shafts made of a stronger material vs. the older T56's, larger bearings to handle more load, thicker case casting to help with deflection.
I was considering the magnum but it can only withstand around 700tq and I want to make sure my driveline is gunna stand up to the 1000 im shooting for. Nothings worse than buying something twice
That "low" 700hp rating is in a 4500lb car launching on slicks without failure.
Says it on the Tremec website.
In car that weighs 1000lbs less you can bet it can hold a ton more power. I've seen these in 1000rwhp+ cars. Nothing is unbreakable.... but they are better than a Stage2 Fbody T56 with an upgraded mainshaft (30 spline Viper). They simply shift better too due to its newer design.
Cheapest, bog standard T56 and wait til it fails.
