wont go into gear when runing please help
just put the motor and trans back in the car had to replace the hydraulic clutch line the clutch and master and slave and throw out bearing have around 1500 miles on them and the car was going into gear before the new motor just fine goes into the gears when the car is off fine so the clutch is not compressing enough any ideas why this would be happening ? my only choice to pull the tranny out ?
my brother dropped the disk installing it this time but it looked ok is there any way to tell if all the air is out the line is brand new and when i bleed it im not getting any air only fluid when i bleed it
"your brother dropped he disc"....maybe someone from a clutch co. could advise if damage is possible.
Given the hydraulic line swap...I would look closer to the bleeding and confirm no air is still in the system.
i bought a vacuum bleeder kit and put it on the hole in the reservoir and pump it like the thread shows on here and i get bubbles then i get non i remove it and start it and try to put it in gear with it running still wont i try again i get more bubbles till non and repeat and same results could my master cylinder have bad seals or something ? its not leaking under the car or from the master cylinder that i can see any ideas?
