Weird Clutch Issue
Only problem I'm having is taking off from a dead stop, the clutch will start to grab, then the pedal will physically push back at me, and then it seems the clutch grabs the rest of the way and thunks. Then im stuck in first. I then have to press the pedal down, which at this point is super stuff, let up, and at this point it's super mushy, pump it a couple times, and then I can shift into second. This scenario is especially prominent taking off from an uphill incline.
Another thing it is doing is at full throttle, when I go to shift, it won't let me, it's stuck in the gear, and I have to go through the same process as explained above to get into the next gear.
Normal driving shifting gears is smooth and effortless. This is only at a stop and full throttle. To add, it is usually random. But happens 80% of the time. I flushed out all the old black fluid that was in the car and bled it for a good hour till it was "clear." Same issue.
I bought a new master from GM and I am hoping it fixes it, and ill be doing the drill mod in the process.
Any input guys?
