rookie tranny problem
Old Apr 30, 2004 | 09:50 AM
rookie501's Avatar
Default rookie tranny problem
This is my first post so I hope you all can bear with me. Out of the blue this happen. I went to go driving around a few weeks ago, when I noticed that every time I tried to shift into 2nd, it would grind and then go in. It has been doing it ever since. I also noticed that if I shift very slowly into 2nd, it will go in no problem. It only does in second gear.
Old Apr 30, 2004 | 09:57 PM
SSmokin 01's Avatar
Do you have an adjustable master?
Maybe need to bleed the clutch?
Old Apr 30, 2004 | 11:08 PM
SMOKIN01TA's Avatar
sounds like the clutch isnt releasing all the way. like was said before, bleed it or get a adjustable master
Old May 1, 2004 | 11:29 AM
rookie501's Avatar
I was told that the 2nd gear syncro mostly is causing the problem. No, I still have orginal master. I wanted to check with guys first before I did anything.
Old May 1, 2004 | 11:34 AM
rookie501's Avatar
I just dont understand why it only does it in second gear.
Old May 1, 2004 | 12:37 PM
SMOKIN01TA's Avatar
opps, i missed the part about only doing it in second. try going from 1 to 3rd and see what happens. my old ta did this crap but it was because i couldnt fully disengage the clutch without a master. if it goes 1 to 3rd than it might be the syncro
Old May 1, 2004 | 08:43 PM
rookie501's Avatar
It does shift from 1st to 3rd no problem.
Old May 1, 2004 | 08:49 PM
crainholio's Avatar
Sounds like you have a variation of my problem...mine upshifts 1-2-3-4-5-6 no problem, but trying to downshift 3-2 it physically won't go into 2nd unless I double-clutch, in which case it's silky smooth.
None of the road courses I race on require a 2nd gear downshift so it's not a show-stopper, I'll do a teardown over the Winter.
