Aluminum flywheel street-ability
Old 08-22-2013, 07:23 AM
HioSSilver's Avatar
Then 3.90 it is. 4.10 would work a little better at the drag track. I don't think you understand gear vs speed vs tq multiplication. 3.73 may even work better, it could even allow you to use 1st gear in some tight turns.
Old 08-22-2013, 08:52 AM
Apocolipse's Avatar
I know how it "works" but I don't fully understand how to implement it properly. I understand wanting to be going through the traps in 4th as thats one less shift to worry about. Just figured road race wouldn't matter and a higher rear gear would let me use 5th more often.
Old 08-22-2013, 09:45 AM
SPEC-01's Avatar
The same basic principle applies to road-racing. Shifting adds to the time it takes around the track. If you aren't making yourself slower out of corners and you have plenty of top-end with 4 years then why add a 5th. This is all relative due to the differences in tracks. Some will require more gear and some less!
Old 08-22-2013, 10:05 AM
Apocolipse's Avatar
I would typically hit around 240-250km on the back straight of Mosport when I am out for track days. I know thats not very fast but at that... I am into 5th any how considering redline is around 6500.
Old 08-22-2013, 01:42 PM
SNLPerformance's Avatar
The difference in 3.90s and 4.10s in 5th at 6500rpm is 172mph and 164 or 275kph and 262 fwiw
Old 08-22-2013, 01:56 PM
Apocolipse's Avatar
Which places me in a point where either 410 or the 390 will work for my application. The 410 still lets me stay in 5th down the straight plus allows me to get off the line a bit quicker with the lightened fly.
Quick Reply: Aluminum flywheel street-ability
