You with turbo and manual, what gear and rpm do you start with?
Old 09-11-2013, 06:45 AM
Turboswede's Avatar
Default You with turbo and manual, what gear and rpm do you start with?
Hi
You guys with turbo and manual gearbox, what gear and rpm do you start with?
Would be fun to see, please also tell your best 1/4 time and 60 feets.
Old 09-11-2013, 03:25 PM
3pedals's Avatar
Depends in your engine/turbo combo.
My setup makes peak power at 6700, I shift at 7000
I geared my car to cross finish line as close to 6700 as possible, which is 3.73's in my case, with 28x10.5 slicks
I launch at 4800 on 2step , car has gone 9.57@146.9. 1.52 60 fts so far, I'm still working the combo, it will go bottom 9's I'm sure
Old 09-11-2013, 06:27 PM
Tally TransAm's Avatar
3.70 rear gears
launch on the 2 step between 4800-5200 depending on conditions, shift at 6200 (need to swap turbine housings to pull it higher)
car went 10.39 @ 136 last time out on a high 1.5 i believe
Quick Reply: You with turbo and manual, what gear and rpm do you start with?
