Pressure plate ?
Pressure plate ?
Clutch guy's. If you put a straight edge on the face of a pressure plate and it made contact on the outer edges but you could fit a .009 feeler gauge on the inner edge would it ever last? And if it did last would it even make contact on the inner edge?
generally most machine shops don't. I have heard and seen pictures of people who have but every shop I contacted locally said they don't do them.
contact the PP manufacturer about your finding. "MAYBE" it becomes flat once PP is depressed
FWIW I measured a spare used PP for my LT1, same as you. the inside is lower....but wear pattern on it, disc and FW is even
