Trans rubber mount for Tko 600?
A Rubber/Polyurethane bush with the metal bonded plate that bolts to the transmission mount and on the other side either has a bonded plate with 2x holes for bolting to a chassis plate or threaded holes so a chassis plate can be drilled and screwed through.
I hope that makes sense.
