Is Ram's aluminum flywheel right for me?
A quick run down of the car:
'94 LT1 Trans Am with 350 rwhp, 3600 lbs, 3.73 rear end. It's my daily driver all year on dry days. 2 or 3 times a month it sees hard shifting either on a twisty mountain road or drag strip.
I've been running a Spec aluminum flywheel since I converted to a T56 in 2007. My first clutch was a Spec stage 2 and it chattered like crazy. In 2009 I had the flywheel resurfaced during the engine swap. The chatter went away for a while then eventually came back. In 2010 I replaced it with a Competition Clutch stage 4, had the flywheel resurfaced again and it now chatters like crazy, too. I've also had slight bucking at part throttle cruise with the new engine.
I want to stick with aluminum for weight savings and a freer revving engine. The reason I'm looking at Ram (18 lbs) over Fidanza (12.5 lbs) is because I ran across a thread where someone mentioned a heavier flywheel will help dampen bucking. Is there any truth to this?
After dealing with all this clutch chatter, I also want to avoid warping and I figure a heavier flywheel with more material will resist warping. Ram is pretty much the heaviest aluminum flywheel I could find while still being lighter than the stock iron (24 lbs).
If it is all about road rally/auto x use than a lighter flywheel can be of benefit to get RPM's up quicker....for DD/Drag racing a standard weight FW.
I assume your Golen motor is internal balance so you need a neutral balanced (zero) FW
Given you motor specs and published dyno I would look into your tune....you should be making more power
It's not so much about rally/ auto x or drag racing. Just weight reduction. If I can use a lighter part that performs the same or better than stock, I'll go for it. I've already adjusted my driving to a lightweight flywheel so that's not an issue.
As far as power level I'm happy with the horsepower, but the torque is low according to Golen's dyno sheet. 350 rwhp is about 415 flywheel horsepower after accounting for 15% drive train loss but I should have 60 more ft/lbs of torque than horsepower. I only have 20.
How is the Fidanza as far as warping? Does anyone know how thick the steel insert is?
Fidenza's are fine by me. Never had a problem with it warping......but I have mooved on to smaller lighter things than that.
Your confusing chatter with bucking.
Lighter is ALWAYS better. The factory **** has been to heavy forever.
