LS7 or Monster??
ls7 is self adjusting and heavier than stock clutch , then especially if your on stock hydraulics your asking those stock hydraulics to deal with this heavier clutch than they were designed for and deal with it soon so you can please shift your car at rpm before the sun rises the next day.... mine has had new GM master , GM slave , fluid change in trans , weekly clutch hydraulic flushes via speed bleeder and still wont shift close to what I would consider quickly from other cars I have owned over the years , surely not quick enough to think about a no lift shift.
theres lots of threads in this section about this subject I paraphrased them for you ^
if your going to do it at least buy a light flywheel with it to compensate for the heavy clutch and if that works let me know lol
I have never had holding issues and doubt that a high rpm clutch dump would be an issue ( If I had something other than the 7.5") also passes the "rev test"
I have also driven on stock ls6, ls7, McLeod rst, and always liked the monster more
sorry to the poster if this is abit of a threadjack but it should be pertinent info to you that if you go ls7 you ought to go adjustable master at the same time...I think price for ls7/tick master is similar to monster 2 with no master so money may be a wash for you if you price it out.
The Stage 2 Monster with an 18lbs flywheel weighs just a few pounds less than an ls1 clutch because the Monster Pressure Plate is heavier than the stock pressure plate, so the 18 pound flywheel kind of counteracts that, I've enjoyed the lightweight flywheel as well as my F-Body friends that I've talked into this same set-up. A Stage 2 with a 28 pound flywheel will weigh a few pounds more than a stock LS1 clutch but less than an LS7 clutch, some say the 28lbs flywheel is better suited for drag racing, 18lbs for auto-x/road racing. I don't have to give my car extra gas to get moving like the general consensus thinks, the flywheel isn't THAT light.
I've had my Tick Master and Stage 2 Monster in for about 20,000 DAILY DRIVEN miles I believe and it has been the best mod I've ever done to the car, the pedal gets a little stiffer (C5 pedals get heavier than F-Body pedals with the Tick Master for some reason, but in a positive way, still 100% drivable) but not bad at all, just give the clutch a more positive feel. I've power shifted it and given it some hell some days and it hasn't gotten hot enough to burn (or at least smell) nor has it even gotten the least bit of limp. Monster clutches also comes with EVERYTHING you need to install so there's no guesswork and no need for a shim.
Here's the link that comes with EVERYTHING you need for a nice clean swap
http://www.tickperformance.com/tick-...camaro-firebird/
Here's my set-up:
I won't voice my opinion in this thread as it might be a little biased
